How to detect small AC currents with passive components?
Discussion in 'The Projects Forum' started by daviddeakin, Aug 24, 2009.
  1. daviddeakin
    Thread Starter Active Member
    Aug 6, 2009
    207
    27
    I'm working on a piece of bench test equipment (for testing device gain), which seems to be working, but I need to put the final touches on it.
    Suppose I have a wire carrying a small 50Hz AC current superimposed on a DC current. Say, 0.5mAac on 10mAdc. I want to detect when the AC current falls to zero. Is there a simple way to do this, ideally using passive components.
    At the moment I simply have a 22R resistor across which I'm viewing the AC voltage signal on a scope, which isn't portable!
    I was thinking perhaps of a small transformer with a bi-colour LED on the secondary. The LEDs should flicker while there is AC, but not when the AC has been nulled. I don't have a transformer to try this yet, so does anyone have any other ideas?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Is the AC current always 0.5mA?
  3. daviddeakin
    Aug 6, 2009
    207
    27
    No it varies depending on the device being tested. Essentially, the device gets a 50Hz signal and you adjust a component bridge until the AC current falls to zero- then you know the gain of the device. AC current can be as high as 5mA, but I need to be ble to detect it down to, say, 100-200uA.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Use a current transformer with the appropriate turns ratio as to light the LEDs in your schematic when the current is just 100uA. IF the current is less the LEDs will be off.
  5. n9352527
    Oct 14, 2005
    1,198
    Does it really work like that? I mean, the current transformer with primary current of 100uA can light a LED at the secondary. Doesn't the voltage at the primary must be large for that to happen?
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    Yes and yes.
    Assume the LED takes 10mA with a 2.0V drop.
    Turn ratio of CT = 10mA / 0.1mA = 100. Primary is say 300 turns and secondary = 3 turns.
    Operating voltage of CT primary = Vsec * turn ratio = 2 * 100 = 200V.
