how to detect numbers from phone keypad?
Discussion in 'Embedded Systems and Microcontrollers' started by tuanvoi, Mar 3, 2009.
  1. tuanvoi
    Thread Starter Active Member
    Oct 31, 2008
    56
    Hi all,
    I'm using PIC18F4550. Could someone help me with this?
    I want the PIC to detect the numbers the I press from the phone. Any sample codes or hints would be very appreciate. Thank you!
    Tom
  2. bertus
    Administrator
    Apr 5, 2008
    15,797
    2,384
  3. tuanvoi
    Oct 31, 2008
    56
    so when I use the external DTMF decoder, what will PIC will see at the output of the decoder? Thanks
  4. bertus
    Administrator
    Apr 5, 2008
    15,797
    2,384
    When you read teh datasheet you will find this table:
    Greetings,
    Bertus
  5. tuanvoi
    Oct 31, 2008
    56
    Can someone give me available decoders? The one above is no more available. Thanks
  6. masoodiqbal
    Mar 8, 2009
    #include <16f877a.h>
    #fuses hs,put,nowdt,NOPROTECT
    #use delay (clock=20000000)
    #use rs232(baud=9600,parity=n,bits=8, xmit=PIN_C6,rcv=PIN_C7)
    #byte portc=7//virtual terminal
    #byte kbd = 6
    #include <kbd.c> //key pad driver file see in compiler folder(driver)
    #include <LCD_1.c> //Lcd driver
    unsigned int c;
    void main (void){
    set_tris_c(0b10000000);
    portc=0;
    kbd_init();
    lcd_init();
    lcd_putc('\f');
    while(1){
    c = kbd_getc();
    if (c>0)
    printf(lcd_putc,"\fNow %c Pressed ",c);
    if(c>0)
    printf("\f Now %c Pressed",c);
    }//while
    }//main
