how to destroy old hard drives
Discussion in 'Computing and Networks' started by jmoffat, Feb 20, 2013.
  1. jmoffat
    Jul 18, 2012
    42
    I need to throw out some old hard drives. Not sure whats on them. What is a fast way to destroy these HDs? Should I just use a hammer?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Old harddisks should be opened easily.
    When opened scratch the platters and the data will not be recoverable.
    Also strong magnets may help.
    A hammer could also do physical damage to it.
    Bertus
  3. nsaspook
    Aug 27, 2009
    3,013
    2,362
  4. Robin Mitchell
    Oct 25, 2009
    738
    207
    Sledgehammer works for me. Gives me something I can channel my anger into!
  5. jmoffat
    Jul 18, 2012
    42
    That Youtube video was awesome! I want me some termite. I don't think I will do a web search though. I don't want homeland security poking into my business.
  6. tshuck
    Oct 18, 2012
    3,531
    675
    ...not sure termites will do much with metal;)
    ..I usually go the route bertus described...
  7. #12
    Nov 30, 2010
    16,693
    7,334
    Bertus is right, but I enjoy putting a few bullets through them.:D
  8. Evil Lurker
    Member
    Aug 25, 2011
    117
    24
    I usually scavenge them for parts. Mainly for tantalum caps and schottky barrier diodes and the magnets... those things are wicked strong. Took six of them one time and stacked them together, the could hold a 15lb sledgehammer to my belt loop. Unfortunately the platters make lousy frisbees.
  9. MrChips
    Oct 2, 2009
    12,635
    3,454
    You could put it through the shredder:
    But not your regular document shredder:
    absf and JohnInTX like this.
  10. nsaspook
    Aug 27, 2009
    3,013
    2,362
    Thermite and special burn-bags lined with thermite were the approved emergency destruction methods for sensitive equipment when you had to bug-out in a hurry.
    See page 47 in this old document. http://www.nsa.gov/public_info/_files/cryptologic_histories/history_comsec_ii.pdf
    theonewho, Metalmann and tshuck like this.
  11. radiohead
    May 28, 2009
    474
    31
    I don't think the average joe has thermite grenades lying around the lab. It would be fun to have one though.
    I would recommend degauss then drive a railroad spike through it or whack it a few times with a hand sledge. Make sure the plates inside are broken and rattling around in pieces. The data will not be recoverable.
  12. shortbus
    Sep 30, 2009
    4,095
    1,685
    Don't think any of the ideas will work. All the "CSI" type shows are able to read destroyed hard drives. :)
  13. atferrari
    Jan 6, 2004
    2,666
    784
    Isn't complete formatting enough?
    What about writing garbage on every single byte in the disk?
  14. nsaspook
    Aug 27, 2009
    3,013
    2,362
  15. jaygatsby
    Nov 23, 2011
    185
    23
    Linux boot cd to prompt. Then:
    cat /dev/zero > /dev/sda1 where sda1 represents the hard drive to be destroyed.
    You can also use /dev/random, you can also do this three or four times depending on your desired level of paranoia.
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    run dban on them if they work first.
    Then
    A) Mechanically shred to small chunks, Document Disposal services will usually have the equipment for both paper and drives.
    B) Thermite over soil outside (NOT IN YOUR HOUSE, in case you were wondering.
    C) Most Fun: half dozen or more 5.56 AP (green or black tip) or .308 Rounds tend to do the trick as well, and it's a lot more fun. Be sure to spread the holes around the entire enclosure surface. Whenever the drives built up, we'd have a "Range Day". Again ONLY ON PRIVATE RANGE, observe all safety practices, distance, eye and ear protection. These were shredded afterward as well, but this keeps the shredding company from attempting to read them.
  17. jaygatsby
    Nov 23, 2011
    185
    23
    Just do what I said. It's easy and secure. And free. I have a lot of experience in this area.
  18. gerty
    Aug 30, 2007
    1,154
    304
    They don't have to be AP for this, save them for something
    useful:D
  19. maxpower097
    Feb 20, 2009
    795
    388
    Drill 5 holes through the HD with a nice 1/4" bit. That's what most fortune 500 companies make my friends do that recycle electronics. They then sell the Pc's with no HD's
  20. maxpower097
    Feb 20, 2009
    795
    388
    This is what they have to do after they drill bit it. They make em drill bit it so its visual proof on camera the HD was destroyed. Then it goes on a conveyor into a industrial shredder.
    This is off their site
    HARD DRIVE & DATA DESTRUCTION:
    • We recommend and prefer total destruction of hard drives to ensure safe data removal. Today's data recovery techniques are becoming so much more sophisticated that the only guaranteed way of disposing all of the confidential information on hard drives is by completely destroying them.
    • White Canyon software to “wipe” hard drives and remove data.
    • Our complete physical data and media destruction is performed in highly secured, highly supervised monitored facilities.
    • Each customer shipment is assigned its own distinguished customer number for security and confidentiality. Materials are identified by using this distinct number. We also record and document serial numbers from the hard drives and all other materials to meet recording requirements.
    • Our methodology for hard drive and data destruction adheres to these regulations/acts:
    HIPAA (Health Insurance Portability and Accountability Act)
    Gramm-Leach-Bliley Act (GLBA)
    Bank Secrecy Act (BSA)
    Patriot Act of 2002
    Identity Theft and Assumption Deterrence Act
    US Safe Harbor Provisions
    FDA Security Regulations (21 C.F.R. part 11)
    PCI Data Security Standard
