How to design the feedback loop for the current-mode buck converter?
Discussion in 'The Projects Forum' started by Zhang Jian, Dec 31, 2014.
  1. Zhang Jian
    Dec 31, 2014
    10
    Dear all:
    I am building a buck converter to charge a battery, and the battery and the buck converter have been built, but I need a current mode feedback to charge the battery in a constant current.
    I will upload some files to help you to understand.
    In the first file, you can see the feedback is composed of compensator and modulator (comparator). But this document tells me how to build the feedback in voltage mode not current mode. I know I also need compensator and modulator in my current feedback. and I am not sure the difference of the two modes, because I need keep the current constant. What is more, I think you can understand what I want to build from the first document, because I think it is quite similar.
    And my circuit is like file2, and I will upload the Ltspice file too, if you can download the Ltspice which is free you can check it out.
    Thanks and Regards,
    ZJ
  2. Zhang Jian
    Dec 31, 2014
    10
    The whole circuit with voltage mode feedback and battery.
  3. ronv
    Nov 12, 2008
    3,392
    1,447
  4. Zhang Jian
    Dec 31, 2014
    10
    Hello ronv:
    Thanks, but I need to build the circuit in LTspice, and I cannot find the Ltspice file like ZXTC1009.
    Regards,
    ZJ
  5. ronv
    Nov 12, 2008
    3,392
    1,447
  6. Zhang Jian
    Dec 31, 2014
    10
    Hello ronv
    Thanks, but I think this document cannot conclude the feedback loop I need or I cannot understand this document.
    Regards,
    ZJ
  7. crutschow
    Mar 14, 2008
    13,466
    3,356
    That circuit seems to be rather complex for just charging a battery.
    What is the supply voltage, the battery voltage and charging current?
  8. Zhang Jian
    Dec 31, 2014
    10
    Hello
    The supply voltage is 40V, but the output voltage can be controlled by the duty cycle of PWM, so the output voltage is equal to the input voltage multiply the duty cycle.
    the battery voltage is set to be 3300MAh. And the charging current should be controlled under 1A.
    Thanks.
    ZJ
  9. crutschow
    Mar 14, 2008
    13,466
    3,356
    3300mAh (I assume you mean milli not Mega Ah) is the battery capacity, not its voltage.
  10. Zhang Jian
    Dec 31, 2014
    10
    Hello
    Yes, it is milli and the voltage is around 5V.
  11. Zhang Jian
    Dec 31, 2014
    10
    Hi
    I think it should be built by compensator and comparator, but I have no idea how to set the value of components.
    And what is the difference between the voltage mode and current mode when I build the feedback?
    Thanks.
    ZJ
  12. crutschow
    Mar 14, 2008
    13,466
    3,356
    As implied by their name, voltage-mode feeds back the output voltage for regulation, and current-mode feeds back the output current (typically from a small resistor in series with the load) for regulation.
  13. crutschow
    Mar 14, 2008
    13,466
    3,356
    Below is the simulation of a simple hysteretic (bang-bang) current feed-back converter. It shows an average battery charging current of 1A with a 11 mA ripple current.
    An advantage of the hysteretic converter is that it requires no compensation in the feedback loop.
  14. Zhang Jian
    Dec 31, 2014
    10
    Hello crutshow:
    Thanks, and I think the difference between the hysteretic converter and buck converter is the hysteretic need the capacitor, right?
    then you choose another way to build the feedback.
    Regards,
    ZJ
  15. crutschow
    Mar 14, 2008
    13,466
    3,356
    What capacitor?
    The converter I posted is a (hysteretic) buck converter.
  16. Zhang Jian
    Dec 31, 2014
    10
    Hi crutschow :
    Thanks I understand, and I mean in the buck converter it usually has a capacitor in the output.
    Regards,
    ZJ
  17. crutschow
    Mar 14, 2008
    13,466
    3,356
    You don't need an output capacitor for a current-mode hysteretic converter.
  18. MrAl
    Distinguished Member
    Jun 17, 2014
    2,542
    512
    My question would be, how accurate do you really need this charge current to be? Normally for charging a battery you dont need a super accurate current level such as you get from a full blown error amplifier/integrator type feedback system. In fact, if it varied from 80 percent to 120 percent of nominal it would probably still be ok. Normally only the voltage needs to be regulated with any pseudo high accuracy. A relaxed specification on the charge current accuracy means a simpler circuit is possible.
  19. Zhang Jian
    Dec 31, 2014
    10
    Hi MrAl:
    Thanks. Actually, I do not have a idea about the accuracy, because I want to build this feedback loop to stimulate the charging process as practical as possible, so I want to build the feedback loop, as when you charge a battery, the impedance is always changing, so I should keep the charging current constant which is my purpose to build the current feedback loop.
    Regards,
    ZJ
