how to design regulated power supply with 0.00 to 10v
Discussion in 'The Projects Forum' started by bread, Aug 28, 2011.
  1. bread
    Aug 28, 2011
    can anybody suggest which ic regulator should i use instead of lm317?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    What will be the needed current for this powersupply?
    The LM317 will not go lower as 1.25 Volts.
    Bertus
  3. iONic
    Nov 16, 2007
    1,422
    68
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why do you need voltages below ~1.3v? There isn't much of a call for voltages that low.
  5. #12
    Nov 30, 2010
    16,684
    7,322
    My favorite is the LM723 chip with both polarities of voltage supplied to it, and I don't give a rats' Sunday hat why you want to do it that way. The 723 is an old fashioned way to do it, but it's as versatile as you are.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    You could look through the LM317 datasheets, one datasheet I have seen has a circuit in there for using a second LM317 to provide the 1.25v offset and give a supply variable down to zero volts.
    Or just use an opamp with 0v capable input, driving an NPN driving a big PNP darlington. Total parts counts won't be much worse than a couple of LM317s by the time you include all the resistors and caps etc.
