I'll try to remember exactly what I did and replicate it in a simulator.Can you post a diagram of your test circuit, voltages, test points etc?
A BC547, according to the datasheet, has an absolute maximum DC collector current of 100mA. The minimum DC current gain is 110, so that means the maximum base current should be 100mA/110 = 0.9mA.What I did was to first calculate the resistance to get the desired base current, which I decided it should be 20mA from a 3v DC power supply.
It's regulated. I kept on going up until it passed 200mA, then lost track because I was in the 200mA range in both the power supply and the meter... and that's when suddenly the transistor stopped... well, transisting.How much current can your 3VDC supply deliver?
The technical term is transistor'ing. HA! Just kidding It's probably in saturation.and that's when suddenly the transistor stopped... well, transisting.
Hi, that is my problem too. Now I am trying to learn every basic circuits and know deeply how it work and I can draw it on my own.I'm not bothered about using other people's designs; it's about not having to look for a circuit every time I need to do something -you need to know its name, how it works, where to find it, how to modify it, etc- a lot of knowledge that I don't have and that I didn't thought was necessary;
I'm about to start from the point were I left it in my last course: power supplies, which was the first circuit on the program. I found my old electronics book and going to start with it, then check out these 2 websites for basic circuits:Hi, that is my problem too. Now I am trying to learn every basic circuits and know deeply how it work and I can draw it on my own.
I'm sure that will not be my last transistor that stops transistor'ing. Maybe the BC547 is not the idea transistor for me to play with.In your test setup add a resistor between the collector and V+.
Calculate it to allow the max current the transistor can handle.
There is also a power calculation at work here. (volts x current)
There's no better way to learn than to make components stop
component'ing once in a while.
Thanks... it looks more advanced than the other 2 but also more complete in terms of circuits. I'll add it my bookmarks and leave it for when I finish the other 2.Hello,
You might also like the pages of the EDUCYPEDIA:
http://educypedia.karadimov.info/electronics/electronicaopening.htm
There you will find a lot of linkpages with information on all kinds of electronics subjects.
Bertus
The collector resistance does limit the current, but only to a safe value.I'm about to start from the point were I left it in my last course: power supplies, which was the first circuit on the program. I found my old electronics book and going to start with it, then check out these 2 websites for basic circuits:
Basic Electronics Tutorials and Revision and, of course, All About Circuits. Then I'll continue with this one which has many books on practical circuits with explanations of how they work: Talking Electronics.
If any of you know other websites or ebooks explaining very basic circuits, please let me know.
I think that were I made the mistake was in setting the base current on 20mA -apart from not checking out what's the maximum that can go through the collector-. I mean, If I was expecting those 20mA to be multiplied by 650 that would have given me 13A, which is 6 times more than what my power supply can supply. I should have calculated the base current to be 0.15mA in case the experiment worked and I got the 100mA on the collector.
If I used a collector resistance, that would be limiting the current and wouldn't be able to check if the ratio was correct; Am I right?
I see what you mean now.The collector resistance does limit the current, but only to a safe value.
If gain ~ 100 and you put 0.1 ma into the base, you would expect ~ 10 ma C-E.
If you have a 100 ohm collector resistor, what would happen ?
Then try 50 ohms, 200 ohms.
