How to design a switch based on current
Discussion in 'The Projects Forum' started by MarkusL, Feb 27, 2012.
  1. MarkusL
    Feb 27, 2012
    Hello all,
    this is my first post in the forum :)
    I am running into some problems in a solar power related project.
    I would like to switch between different types of 24VDC to 120VAC inverts depending on the DC current.
    I mean I want to use the smaller inverter below lets say 10A and the bigger above that.
    how can I design a circuit to do that?
    thanks
    Markus
  2. #12
    Nov 30, 2010
    16,705
    7,358
    This would work a lot better with more information. The trick is to find a measuring point that won't interfere with proper operation and I can't seem to imagine where that is without seeing some kind of schematic drawing.
    Got a pencil and a scanner?
    How about you make a drawing in paint.exe and save it as a .PNG?
  3. MarkusL
    Feb 27, 2012
    I have created a sketch - sorry, it's only hand-drawn.
    there are 2 inverters (200W and 1000W) which i want to use depending on the load.
    The reason is that the big inverter has a low efficiency on small loads.
    the switch can be a 120V/10A relay.
