How to design a pcb
Discussion in 'General Electronics Chat' started by insanity_embraced, Aug 13, 2010.
  1. insanity_embraced
    Aug 11, 2010
    7
    Hi
    i m actually new in pcb designing, i have downloaded few softwares like FREEPCB, NI Ultiboard, eagle.
    but all of them are little tough to use, like using multisim i can easily place a IC, but here the scenario is different, i just cant understand which footprint is of my IC, and none of them matches mine (74160), i have taken some printout of sample design but they are too small, even my 1 single ic is bigger than the prinout.
    So please help me getting started
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To be specific about your logic IC, the 74160 comes in a 16 pin DIP package. To do the layout, you place a 16DIP (or whatever the name might be) pattern wherever you like, and make connections following the pinout from the IC's data sheet.
    The package any device comes in is standard. The pins used for the various functions may be different for each device.
  3. insanity_embraced
    Aug 11, 2010
    7
    and whatt about 7 Segment Digital Display, Which package does it uses ?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    For chips that are basic unknowns to the software they usually still use a standard pattern, such as the 16 pin DIP. You can link individual pins to networks as I understand it.
    You can usually find a pattern in the library. If not, it is possible to draw patterns yourself, but this is beyond the scope of what I know.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The best approach is to obtain the data sheet for each and every device. With that in hand, you have the exact footprint for the PCB and the function of each pin.
  6. insanity_embraced
    Aug 11, 2010
    7
    I know the function of each pin, but i cannot find the footprint of these display's
  7. n1ist
    Mar 8, 2009
    171
    16
    Do you have the data sheet for the display? The footprint should be there. Otherwise, since you know the pinout, just grab a ruler and measure away. Learning to make your own footprints is an important part of learning to design PCBs.
    /mike
  8. insanity_embraced
    Aug 11, 2010
    7
    i google the datasheet of 7 segment digital display, but couldnt find any..
  9. marshallf3
    Jul 26, 2010
    2,358
    201
    There are many 7 segment (often + a decimal) parts out there but the pinouts isn't necessarily going to be the same on every one.
    You need the data sheet pertaining to the one you're using.
