How to design a metal detector
Discussion in 'The Projects Forum' started by divakar77, Jun 28, 2010.
  1. divakar77
    Jun 28, 2010
    Hai..
    I am designing metal detector, which should detect the metal at a distance range of 400mm.. Please guide me with necessary circuits and 'coil winding structure'..
    Divakar Raj. R
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    How big a piece of metal do you need to detect? What type of metal? Detecting something relatively small at 4 meters will be a real challenge. Most of the hobby projects are limited to 100 cm or less.
    John
    Edit: I just misread the units. Thank you, beenthere. John
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think 400 mm is only 40 cm.
  5. divakar77
    Jun 28, 2010
    The metal detector need to be designed for a conveyer system. The conveyer carries plastic things.. If any metals come with it, the detector should detect it. The metal may be of any sizes. The machine should take only plastics from the conveyer, any metal pieces in it will spoil its blades. This is my requirement. 400mm (40cm) is the required detecting range. Can I use the details from the above link..
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
