how to cut pcb?
Discussion in 'General Electronics Chat' started by Sonoma_Dog, Jun 6, 2009.
  1. Sonoma_Dog
    Thread Starter Active Member
    Jul 24, 2008
    99
    what are some good ways to cut PCB board?
    let say only 2 layers board.
    thanks
    Jlau
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    Well, you could use a dremmel tool. Make sure you wear a respirator though because PCB's are usually fiberglass which you dont want to breathe in!
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Absolutely wear a filter mask and eye protection if you're going to be sawing/grinding/sanding PCB's. If you don't have a filter mask, use an old T-shirt that you've dampened.
    I've used a sheet metal shear, a large paper cutter, nibbling tool, aviation snips, jigsaw, Dremel, etc. If you're going to use a saw, use a blade with very small teeth. There should be at least two teeth in contact with the fiberglass at any one time, or else you'll get a really ragged cut.
  4. John Luciani
    Apr 3, 2007
    477
    I use a hacksaw with a fine tooth blade. I usually cut the boards outside. I always wear a dust mask and safety glasses. If I cut the boards inside I have someone vacuum
    the dust as I cut.
    I leave 50mils between layouts. If you go slow cutting this is sufficient space so
    that you can do one cut between two boards.
    (* jcl *)
