How to create PLC Timer longer than 1 week
Discussion in 'General Electronics Chat' started by pandian, Jan 28, 2011.
  1. pandian
    Thread Starter Active Member
    Sep 27, 2009
    32
    I trying to edit a ladder diagram with OMRON CS1G PLC.
    I need an alarm to be triggered after 3 months.
    If I use a combination of NO instruction with 1 minute interval and CNT instruction, the max count is 9999 x 1 minute, which is equal to 166.65 hours or 6.94 days.
    Is there any other special instruction/timer to count more than that?
  2. Jaguarjoe
    Apr 7, 2010
    770
    90
    How about cascading counters? Compare the count bit of the first counter with a constant 9999 then increment the second counter one step. Reset the first counter and let it count up to 9999 again and repeat. You'll get to ~three months in 12 counts.
    pandian likes this.
  3. pandian
    Sep 27, 2009
    32
    Hi brother,
    thanks a lot. I didn't even thought about it. I'll try.
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    what possible use could a time dependant alarm of 3 months be?, unless it was an embedded service call. Query your system date and time registers.
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    There are, unfortunately, some malicious applications of long delay timers.
