how to correct this error?
Discussion in 'Programmer's Corner' started by simu, Feb 6, 2008.
  1. simu
    Feb 6, 2008
    while compiling my program written for modular division & montgomery modular multiplication in verilog, i often get the following error...
    ----Can not simplify operator REM.
    ----Loop has iterated 64 times. Use 'set -loop_iteration_limit XX' to iterate more.
    can u tell me what it is?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This really belongs in the programming forum, but I'll take a stab at it ;)
    Perhaps you're trying to use REM to indicate a comment, but REM isn't valid for indicating program remarks
    or - you have some sort of piping command on a comment line that's causing the compiler to pick it up anyway, but it doesn't know what to do with the data after the piping command. For example, in MS-DOS .BAT/.CMD files, if you use < or > piping operators after a REM, they are still executed.
  3. chesart1
    Jan 23, 2006
    269
    I'm not familiar with Verilog, but if you provide the code that caused the error, perhaps someone could help.
  4. RiJoRI
    Aug 15, 2007
    536
    26
    My guess at "Loop has iterated 64 times. Use 'set -loop_iteration_limit XX' to iterate more." is that VLog has a built-in safety to keep it from an infinite loop. Enter the command they suggest using, say, 100 in place of the 'XX', and see if you get the same error. If so, there is probably something wrong with the coding.
    --Rich
