How to Convert Sinewave input to Sqaurewave output ?
Discussion in 'Homework Help' started by BankSan, May 3, 2011.
  1. BankSan
    Apr 29, 2011
    Anybody, Could you help me plz.
    Can I use IC comparator TLC3702 for change sine to square, Right?
    I already had input source which specification as below :
    - 2.5 Vrms sinewave
    - Frequency range are 1k to 100kHz
    - Power supply +- 15V
    And my output as I need, How to do?
    - 0 to 5V squarewave
    Note. I don't know how to make the circuit diagram.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Welcome
    All you have to do is pass the signal through a High Speed schmitt trigger
    See here or read this document
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can use the device number - "TLC3702" - as the search term in Google to find a data sheet.
    Since the output is 5 volts, an open collector comparator would be helpful.
    You can always draw on paper and scan a schematic or grab a freeware CAD package.
