How to convert printed layout to circuit schematic diagram
Discussion in 'The Projects Forum' started by obas, Dec 28, 2010.
  1. obas
    Dec 27, 2010
    Dear Members,
    I would like to know if it is possible to convert a printed circuit layout drawn using ExpressPCB back to Schematic diagram on the same ExpressPCB software and how to do it.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    Directly?...Short answer is no. But, it could be done manually, building the schematic as you think it's arranged. Save the schematic, link it back to the PCB, and use the "Highlight net connections" function to verify your schematic connections. Might work on small circuits where you have an idea of its configuration. I've reverse engineered small PCB's...but it's not fun. ;)
    Ken
  3. retched
    Dec 5, 2009
    5,201
    313
    Yeah... good luck.
    There is no information (besides connections) that would tell the schematic capture program where the components were laid out.
    It would be possible to just throw all the parts with connections on a screen, then let YOU place them in the schematic, but I haven't seen it done.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    That is exactly what I've done...again on small PCBs. Also, took a picture of the board and highlighted the traces on the image as I connect the components on the schematic. It also takes some knowledge of how you would expect the schematic to be functionally arranged in the end.
    Ken
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Out of curiosity, I searched on "reverse schematic capture." Several hits, many of which are firms offering to do reverse engineering for you. This hit claims to be able to do schematic from PCB.
    John
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Can you post the link to the actual page that you quoted?
    If we want to see the home page, it's a lot easier to navigate backwards than it is to find the needle in the haystack.
  7. retched
    Dec 5, 2009
    5,201
    313
    RonH, that is the page. Click on the 'Specifications' tab and it is listed there.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    So it is. I thought I had searched all the tabs.:(
  9. retched
    Dec 5, 2009
    5,201
    313
    Com'on Ronnie! Were here to help each other!
    Not a problem. Never a problem.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    That's funny! Ronnie is my legal name. No one here has ever called me that before. Did my new avatar inspire you, or was it just coincidental?
  11. retched
    Dec 5, 2009
    5,201
    313
    It was the avatar.
