How to convert directly 3 phases motor supply into 1 phase in the motor application..
Discussion in 'The Projects Forum' started by muthuaiyan, Aug 8, 2014.
  1. muthuaiyan
    Aug 4, 2014
    19
    Dear frnds,
    i have a doubt that ,can we change over the three phase motor supply into single phase motor supply directly??
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Use two phases, if the voltage matches the motor.
    Max.
  3. crutschow
    Mar 14, 2008
    13,472
    3,361
    I don't understand. :confused: Wouldn't you use just one phase to drive a single-phase motor?
  4. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Across two phases IS single phase. At least that is what I intended to mean.
    Unless you also have 3 phase and star connected transformer source.
    If you have, you have two 1ph voltage sources of a different voltage value where either could be compatible with the motor.
    Max.
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  6. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Presumably the 1ph motor would already have the split phase caps in place?
    At least the way I understood the OP, he wanted to run a 1ph motor on a 3ph supply?
    Max.
  7. crutschow
    Mar 14, 2008
    13,472
    3,361
    Okay, I understand. Of course across any two of wires of the 3-wire 3-phase connection would give a single phase. When you said use two phases I was thinking something else. ;)
  8. crutschow
    Mar 14, 2008
    13,472
    3,361
  9. Electric Al
    Member
    Nov 6, 2013
    59
    8
    P8090015.jpg I hope this helps !
  10. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Basically what has been said, Although it does not show the phase to star neutral option.
    Max.
