I am currently working on a analog active noise control circuit that uses a 2 second long music piece as an input. The circuit works fine. The output when viewed in Cosmoscope is satisfactory. But I need to convert it into a sound file (any format) in order to check its reproducibility and integrity. Is there any software to do this ? I tried some software to change the output data formatted as a csv file into a wav file. But they have not worked so far. I am still searching for a possible way to solve this . Please help. Thank you
