How to convert .c file to .hex file (babupremkumar71)
Discussion in 'Embedded Systems and Microcontrollers' started by debjit625, Aug 6, 2011.
  1. debjit625
    Apr 17, 2010
    790
    186
    This mail was from babupremkumar71 on 08-05-2011.
    On behalf of him I am posting this thread.
    All about circuits is an open froum so please don't ask your questions through e-mail rather post a new thread so that other people having same problem could get some help from your post...
    Any C compiler which can produce *.hex fromat binary will do it.
    A mcu executes code you may say program,and C compiler is just a program.So if you can write a C compiler for your mcu then it will contain a C compiler.But I think you didn't ask about that...may be you wanted to know which mcu supports C programming language.All the mcu supports C programming,you just need a C compiler for the target mcu.C compiler just converts the high level C language to mcu's own native language.Like for example for Microchip's PIC I use HI TECH C compilers under MPLAB.
    As per me both are best,it depends on the application.
    You asked nothing wrong,just ask it on your post.
    Good Luck
