How To Convert Binary Code To Bcd And Vise Versa?
Discussion in 'Homework Help' started by transgalactic, May 8, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
  2. mik3
    Feb 4, 2008
    4,846
    63
    Search google , you will find thousands of answers!!
  3. techroomt
    May 19, 2004
    198
    you need to first understand "binary" and "binary coded decimal". when you do it is easy. read up on both.
  4. transgalactic
    Apr 29, 2008
    74
    i know that BCD is a sub group of binary numbers from 0-9
    so i dont know how to convert 1111 to BCD code (its impossible)
    or 0011 to BCD (it stays the same)
  5. mrmount
    Dec 5, 2007
    59
    7
    I suppose you have to convert binary to decimal and then convert it to BCD. So 1111 would become 0001 0101.
  6. Caveman
    Apr 15, 2008
    471
    BCD is just a method of using 4-bit values to represent a digit of a decimal number. The 4-digit codes, 1010,1011,1100,1101, and 1111 are invalid because they would translate to 10-15, which are not decimal numbers.
    You can see that BCD is more inefficient that binary, but easier to directly read.
    1111 is invalid as a BCD number directly, but as binary it is equal to decimal 15, which will require two BCD digits 0001 and 0101.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
