how to convert a variable dc to constant supply
Discussion in 'The Projects Forum' started by Afeesh, Sep 17, 2009.
  1. Afeesh
    Jun 12, 2009
    9
    hi,
    i am having a variable dc voltage having a max peak value of 3.5V (varying from 0 to 3.5 voltage ), i want to convert this to a constant dc supply.Plz suggest any simple method to do the same.
    to be specific i am having an output that can blink the led but the led blinking is highly fluctuating (changes its intensity in every instant).i want to convert this fluctuation to a constant output voltage.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    What is your required constant DC output voltage?
    Clearly you won't be able to convert an input of 0V to anything other than 0V - unless you have a means of storing energy for the time the input is at zero volts. So if the input might be at 0V for a 'long time' you may have to set your minimum variable input to something greater than 0V.
    Perhaps you could define your requirements in more detail.
