How to Convert 5V DC to 12V DC?
Discussion in 'General Electronics Chat' started by GeorgeBurgess, Nov 4, 2012.
  1. GeorgeBurgess
    Nov 4, 2012
    I have a power supply with a different connector, and output (on one of 24 pins) to the circuit input I am attempting to use it with, so basically I got an electronics engineer I know to make an adapter up for me, he did a great job in doing so however I have one issue, one of the pins of this adapter's input side is of 5V DC but I need it to be 12V DC on the output, the engineer used a simple 0-240V to 12V transformer however this doesn't appear to be working.
    What is the best way to achieve this 5V DC to 12V DC conversion? Thank you in advance.
  2. BringMeAnother
    Oct 21, 2012
    12
    I'm no expert or anything, but I have been interested in the question and found the LM2577.
    Edit: I'd be interested in finding a better or more efficient way. I need that 12V output too.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A 12V transformer produces a peak voltage of (12V x the root of 2=) 17V. A bridge rectifier reduces it to 15V at a high current or a little more at a low current. A filter capacitor charges quickly to 15VDC and can feed a 12V regulator.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Provided the your current requirements are meet, you could use a DC-DC boost converter.
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Audioguru has the answer; rectify the raw 17V ac and regulate it with a 7812.
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
    what current level?
