For testing I will definitely need to have everything adjustable, but once I've got it all figured out I will want to set the values of everything so that it can't be changed.
I suppose the comparator can be figured out during testing, like you mentioned. I'll look up those other ICs and see if they have schematics that can explain the comparator system to me a little bit better.
For testing in LTSpice, I would just eliminate the TL494, and supply a square wave to the transistor that drives the MOSFET, and 12V to the inductor before the MOSFET?
I expect to have to work through plenty of mistakes, that's how you learn!
The MOSFET I'm planning to use for the solenoid is this one, and it says that it's Vgs is 4.5V. It also has a threshold voltage of 20V, though. I'm not entirely sure how to interpret those numbers, but from everything I've read, 4.5V should be enough to activate it.
If not, I'll just add an NPN like you mentioned.
Regarding the Thai schematic -
The hardest part I've had with all of this is just grasping the insane amounts of information that I've learned in the last 5 days. When you posted that Thai schematic, I couldn't even look at it without being overwhelmed. I had no idea what I was looking at, and pretty much just ignored it.
Now that I've had some practice reading and building schematics, it's not nearly as difficult to understand, and I can actually pull information from it.
It has definitely been fun jumping in feet first into something that I had zero experience with before starting.
