takao21203
- Joined Apr 28, 2012
- 3,702
The truth is initially when the capacitor of a dc/dc is empty, the dc/dc needs to supply a large current.How would I determine what toroid I need to use? They don't look overly complicated to make, so I could do that if I could just find the core I needed.
Also, if I'm using a capacitor to provide the initial 36V to the solenoid, could I use a lower amperage DC/DC to charge the capacitor? That way I wouldn't need to build a 10A unit, I could just use one of the ones you linked on ebay.
A 10000uF cap. does not take long to charge up using a dc/dc in this power class. Considerably less than 1 sec.
Yes you could use a dc/dc with let say 2 Amps. capability.
Given the fact that the duty cycle for discharge from 36v to 12v is very low.
10000uF only as reference for a starting point, even if I think this value might work.
yes you fully understand it.Okay, it shouldn't be too hard to make sure the DC/DC goes off when the solenoid comes on.
I don't really want to overload the DC/DC, I don't want to have to worry about stressing the components and having potential premature failure issues.
I like the capacitor idea, I think it will work nicely, and if I can use a lower amperage DC/DC, then it will allow me to keep the heat down.
So just to run through everything, to make sure I have understood everything up to this point...
Start with a 12V source, send that to the DC/DC and get 36V. Send 36V to the capacitor to charge it, then run the capacitor to a MOSFET that is activated by my IC output. Run 12V source in parallel with the capacitor with a diode to prevent reverse current. When it is time for the solenoid to be fired, it receives 36V from the capacitor, until the capacitor is discharged, at which point it receives 12V from the source to remain closed until the IC ends its firing sequence.
Does that sounds right?
Don't worry about overloading a dc/dc for short time. They need to have such capabilities anyway.
If youhave for instance 5 Amps. steady current, normally you would use a 10 Amps MOSFET, or better 15 Amps.
If you work a MOSFET very close to it's margin, chances for failure are much greater. BJT (for instance power NPN) are a bit more robust.
I use for instance a TIP36C, with capability of 32 Amps, and surge capability of about 100 Amps. That never will be reached because the wires are too thin... Max. current is only 12 Amps.
I made experience with MOSFETs working them more close to the margin, and they burned out instantly when overloaded (having high temp. already).
Depends if you can obtain suitable transformer cores. But the effort is much more, especially if you have not build circuits like this one before.How does a boost converter compare to a push-pull converter in terms of cost? What about overall temperature during operation?
Be aware there are many different magnetic materials used for toroid cores.
Yes they are not difficult to make, but sometimes all the space is filled up with magnet wire.
If the magnetic properties are unknown or not fully known all you can do is to add magnet wire, and try the coil in a circuit, and see about the efficiency.
Some coils will result in rather low efficiency because their parameters don't match the circuit. It is possible to improve it trying different diameter magnet wire and so different turns.
When I built my TL494 circuits, all cores I had here produced rather low efficiency. In the end, I used a ready-made 700uH toroid inductor, which works quite well.
So if you produce a PCB, prepare it for different coils, maybe a screw terminal would be appreciate.
And over-dimensionate the MOSFET or BJT.
I don't think max. efficiency is so much important here, but something close to 70% is desireable for any SMPS or dc/dc circuit.
The choice of power level must be made by you, if you want to try 2 Amps capability only, to charge a capacitor, even eventually use a small power resistor to limit charge current, or to build 5 Amps, 8 Amps etc., and overload it for a short moment.
