How to convert 12V 1.0 A DC to 3V DC
Discussion in 'General Electronics Chat' started by beingsallu, Jul 14, 2012.
  1. beingsallu
    Jul 10, 2012
    18
    hello every one
    I want to convert 12V 1.0 A DC to 3V DC
    is that possible if yes . so please tell me
  2. #12
    Nov 30, 2010
    16,704
    7,347
    It is possible. You can use a voltage regulator or a DC to DC converter.
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
  4. wmodavis
    Oct 23, 2010
    737
    150
    It definitely possible, in fact that sort of thing is routinely done all the time.
    Voltage divider, zener diode, voltage regulator,
  5. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
  6. ravishankar kv
    Jul 14, 2012
    8
    if output current required is less than 1A then try 7803. better use a heat sink along with that.
    beingsallu likes this.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    You can get a free finished design for this from National Semiconductor. Use their Simple Switcher software. Schematic, parts list, the whole banana. No heatsink required. part number LM2575-ADJ will work for it.
  8. crutschow
    Mar 14, 2008
    13,501
    3,375
    A linear regulator is simple and will give an output current of 1A maximum @ 3V with a loss in the regulator of about 9W.
    A switching regulator is more complex but can give an output over 3A maximum @ 3V with a loss in the regulator of a couple watts or less (depending upon the switching regulator used).
  9. beingsallu
    Jul 10, 2012
    18
    can you tell me circuit schematic of 7803
  10. #12
    Nov 30, 2010
    16,704
    7,347
    There is no such thing as an LM7803. Use this.
  11. takao21203
    Apr 28, 2012
    3,578
    463
    I'd be curious to understand what is so complex about 4 components. Which I never calculate in any kind.
  12. #12
    Nov 30, 2010
    16,704
    7,347
    Nice photo. Do you have a schematic of this 4 component switching regulator?
  13. takao21203
    Apr 28, 2012
    3,578
    463
    Yes. Also LED is added to output + 1K resistor.
    Timing capacitor can have different values,
    I have measured lowest input current with 68pF.
    50pF, 180pF, 470pF etc., all ceramic caps.
    If you use electronic transformer, input cap. is not strictly neccessary!
  14. #12
    Nov 30, 2010
    16,704
    7,347
    I think I just became a fan of the simple switchers.
    I wonder if they can be purchased in New Delhi.
  15. tpny
    Member
    May 6, 2012
    216
    I would think it depends on what u will be using the 3V for.. When I needed a voltage source to drive two 3.3V ICs, I used an encapsulated DC-to-DC converter (eg, Mean Well DKA15A-05) to step 12V down to 5 then an LM1117. You can also get one to step 12V down to 3.3 in one step. (I needed 5V and 3.3V on the same board.) I'm not sure: could I have done the same with an MC33063/4 like above?..
  16. beingsallu
    Jul 10, 2012
    18
    with using LM317
    R1-220 ohm
    R2-470 ohm
    output-3.92v
    is capactiors are must for this
    if yes tell me which one ?
