How to control voltage on a DC power supply
Discussion in 'The Projects Forum' started by Gdrumm, Feb 25, 2009.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I am taking a class on DC Circuits, and I would like to be able to re-create a lab we did at school, at home. I have a 24 V power supply (AC Adaptor), but it's output is more like 30 volts....
    How can I wire in an old volume control type switch to turn down the voltage?
    The outside of the AC Adaptor plug is +, the inside is -.
    My old volume switch has three wires coming out of it, and it's only ID marks are M 5KD.
    See bitmap attached.
    Thanks,
    Gary
  2. Gdrumm
    Aug 29, 2008
    684
    36
    Oh yes, and how can I protect my power supply from an accidental short?
    Where would I put a fuse, and how large a fuse do I need?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You would need to use a device like an LM317 to do the actual control, but your 5K pot is potentially (little joke there) useful to change the output level of the LM317.
    Here is a link to a data sheet that tells you how to use it - www.national.com/ds/LM/LM117.pdf.
  4. Gdrumm
    Aug 29, 2008
    684
    36
    I skipped trying to control the voltage, and moved on to re-do the lab, substituting my voltage for theirs.
    When I treid to measure current, it gave me a brief reading that quickly began to drop. The AC adaptor is rated at 24V 500mA.
    Do such adaptors have a safety mechanism built it to cause them to drop like that?
    I tried for several hours, using different meters, all with the same result.
    I was unable to measure current for each resistor in the parallel circuit.
    Any clue as to what went wrong?
    Thanks,
    Gary
  5. jamers
    Member
    Jan 24, 2008
    12
