How to control AC powered device using MCU?
Discussion in 'Embedded Systems and Microcontrollers' started by allahjane, Dec 9, 2012.
  1. allahjane
    Sep 19, 2012
    75
    Hi all,
    Short explanation:
    I give 5v to [power control] --> AC Device ON
    I give 0v to [power control] --> AC Device OFF
    please advice simplest & cheapest option for [power control]
    P.S>I will not use relays
    Long Explanation:
    Basically I want to switch the AC (230V 50Hz) powered device on/off as per the MCU signals (Programmed logic )
    for signalling I have 5v from normal I/O pins
    I have considered Mechanical relays but I don't think they could run on the low current from the I/O pins .. further more I do not want to add a motor driver to control the relay as it will make the design more complicated and much of the power will go for keeping the relays engaged!
    So,I am looking for an electronic device/circuit for the purpose such as a MOSFET or something called as TRIAC
    But, I am pretty dumb at electronics
    can someone recommend a decet way to control the AC power to device using just the 5 v
  2. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Nothing says you can't drive the relay with a transistor or MOSFET.
    There are a number ways to do this.
    Solid state, relays, optocoupulers etc.
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    Look at this:
    http://www.fairchildsemi.com/ds/MO/MOC3042M.pdf
    The MOC3043 only requires 5ma drive current, drives a suitable Triac very simply.
  4. John P
    Oct 14, 2008
    1,639
    225
    The trouble with triacs is that they inherently involve connecting your low-voltage electronics to the high-voltage line. This really is something to avoid in anything you build yourself, and I believe talking about it violates the terms of service for this board.
    The opto-isolator component is usable, though it still puts the high and low voltages very close together. And that little device isn't good for much current.
    I think you should use a solid-state relay. Much closer to foolproof, can handle plenty of current, can be driven by a microprocessor output pin, don't cost much.
    Pictures of several types here:
    http://en.wikipedia.org/wiki/Solid-state_relay
    Note that "trouble with triacs" is not the same as "trouble with tribbles".
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    Thanks for reminding me :).
    Just don't feed them.
    I'm heading to the shop now to work on my rudimentary lathe. :D
  6. ErnieM
    Apr 24, 2011
    7,445
    1,628
