how to construct a automatic voltage regulator for a generator using microcontrollers
Discussion in 'The Projects Forum' started by roymor, Nov 4, 2012.
  1. roymor
    Nov 3, 2012
    i have a rotary converter generator (208v, 400 hz, 3 phase, 30 kva)
    can you lease help me out with a circuit for designing its avr module,
    its old avr module has burnt out
    previous avr used to take input feedback from all three phases of main winding
    and neutral
    line voltage = 208v u-v, v-w, w-u
    phase voltage =120v u-n, v-n, w-n
    the exciter field resistance =129 ohms
    the three main windings are healthy and are showing equal ohmic value of 0.3 ohms
    with previous avr module following were the exciter field current an exciter field
    voltage at no load
    exciter field current = approx 0.3 amps
    exciter field voltage = approx 36v-38v
