How to connect TPA7297 S-GND and PW-GND
Discussion in 'The Projects Forum' started by Will Edwards, Dec 28, 2015.
  1. Will Edwards
    Dec 19, 2015
    I've just started making an amplifier for some speakers and I'm completely new to this and couldn't find any information in the documentation explaining it. So I just wanted to know if S-GND and PW-GND can be connected to a common ground back to the negative battery terminal? If not how would I go about connecting the grounds up?
    Datasheet: http://www.st.com/web/en/resource/technical/document/datasheet/CD00001048.pdf
    Thanks in advance :)
    Will
    *EDIT* I'm making the standalone version
  2. SLK001
    Nov 29, 2011
    851
    243
    Quick answer is yes. If you look at the datasheet, their layout connects these signals together.
    Will Edwards likes this.
