How to connect thermostat
Discussion in 'General Electronics Chat' started by SamLawPk, May 14, 2015.
  1. SamLawPk
    May 14, 2015
    Hi, If I have a Digital Thermostat Module Model XH-W1209 . How to connect it with a 12v 10a thermoelectric module TEC-1 12710 , 12V 0.1A fan to a 12V 9A dc supply ?
  2. Dodgydave
    Jun 22, 2012
    5,138
    767
  3. Stuntman
    Mar 28, 2011
    189
    50
    On your XH -1209, the K0 and K1 terminals are basically a switch (they are the contacts from a relay controlled by the thermostat).
    Knowing this, you should be able to hook up your thermo module and fan like this:
    Now, if the 12V supply is ONLY powering the peltier and the fan, you could actually hook the supply up to both of the devices, then simply route the power for the 12V supply through the thermostat.
  4. SamLawPk
    May 14, 2015
    Thanks for helping. I am new to those thing. I understand the part that you have drawn, but how to route the 12v supply through the thermostat? Can I do it like the way Dodgydave provided link, just as the 12v connection?
  5. Reloadron
    Jan 15, 2015
    1,038
    267
    Yes, as Stuntman drew it out. K0 and K1 are the open relay contacts controlled by the thermostat.
    Ron
