I bought the PICKit 2 on the advice of some of the people here. prior to that I had pruchased a Velleman development board.
The velleman board actually had places I could insert the PIC, the PICKit 2 came with a 44pin board but you cant put your own uControllers into the board, you can only use the sample one they give you.
As the PICKit 2 connects to the microcontroller via a 6 pin specially manufactured connection, I wondered how am I supposed to connect it to a PIC? can I buy JUST the 6 pin connect with correct spacing to fit into the PICKit and how would I know which pins to connect to and from?
Im a bit confused about how I would basically connect my PICKit to a uController
