how to connect stepper motor?
Discussion in 'General Electronics Chat' started by engrrehmat, Mar 12, 2011.
  1. engrrehmat
    Dec 17, 2010
    26
    i have an stepper motor, vexta, model PH266-02GK, i can not run the motor i have tried alot, how i should know the wire configuration and how should i run it, plz help me it is urgent.
    the motor image is also uploaded.
    the motor is 12v and 0.6A. and 2 phase. bipolar.
  2. mjhilger
    Member
    Feb 28, 2011
    119
    16
    Stepper motors require alternating pulses (there are 2 windings may or may not be center tapped) You have to supply pulses at the appropriate voltage and current and width, and frequency to drive them to your desired need. Stepper motors CANNOT be driven by direct connection to a battery or step down transformer. You must have a drive circuit of some sort. Many off the shelf drivers are available, or you can use a microcontroller with FET's and the power supply necessary to drive the motor. It is not a simple connect the wires and go!
    Sorry, probably not what you wanted to hear.
    engrrehmat likes this.
  3. engrrehmat
    Dec 17, 2010
    26
    thx.
    i have the darlington pair and microcontroller, but don know the wire configuration of the motor. therefore i am stuck,.
  4. shortbus
    Sep 30, 2009
    4,094
    1,677
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here is a scanned datasheet of your stepper:
    http://www.ece.wisc.edu/~morrow/ECE315/vexta.htm
    Notice the wire colors and connections at the very bottom of the sheet.
    Note that these are unipolar motors; the yellow and white get connected to +12v.
