how to connect stepper motor using microcontroller 8052?
Discussion in 'Embedded Systems and Microcontrollers' started by engrrehmat, Mar 8, 2011.
  1. engrrehmat
    Dec 17, 2010
    26
    i want to replace the motor in my project with stepper motor, the detail is,
    the circuit is built using microcontroller 8052 and this is connected to ULN2803 IC and the H-bridge using TIP147 and TIP143, four transistors each because there is two simple motor. the problem i cant understand is that how i connect the stepper motor, should i simply replace the motor or need to update the circuit also.
    please help me.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    An H bridge is quite useful for controlling a DC motor. However, a stepper motor is a very special case of DC motor and requires a different methodology - http://www.cs.uiowa.edu/~jones/step/
    Depending on the current requirement, that ULN2903 may be useful.
    engrrehmat likes this.
  3. engrrehmat
    Dec 17, 2010
    26
    how i can know the wire configuration of PH266-02GK stepping motor, i mean the common and vcc.
    i am confused as it has got 6 wires.
    the colors are
    1-black
    2-dark pink
    3-blue
    4-yellow
    5-white
    6light green
