Hello, I have some problem here. I am using relay srd-12vdc-sl-c. how to connect that type of relay with 40W bulb? i really need your help. thankyou
Is your relay something like this http://www.uctronics.com/12-vdc-songle-power-relay-srd-12vdc-sl-type-p-150.htmlHello, I have some problem here. I am using relay srd-12vdc-sl-c. how to connect that type of relay with 40W bulb? i really need your help. thankyou
That is new question somewhat far from that you asked first. Ok first thing first. Have you worked with transistors before? You will need a transistor used as a switch in this setting. And also just to be sure, you have access to a 12 volt power supply for the relayyes! then how to connect it to bulb and arduino?
