How to connect NSI45030T1G in led circuit
sunday01
Joined Dec 18, 2014
Dear all,
Would you please help me with this circuit. I have a voltage source vary from 9V to 18V. I am using Osram LWE6SG .
Is it enough for turn on the LED?
If the circuit is not correct, would you please give me a reference (just simple because my PCB is very small 2x3mm).
I would very much appreciate any help or guidance you are able to give me.
Thanks,
Sunday
Jony130
Joined Feb 17, 2009
5,488
Well your circuit looks good but have you checked a power dissipation in current source?
Also are you gonna to use a single LED only?
Alec_t
Joined Sep 17, 2013
14,312
Welcome to the forum!
So how are you going to mount D3? Its maximum dimension is 3.86mm and it requires 100mm^2 of 1-oz copper pad to handle 208mW max. With a 9V battery D3 will be dissipating ~180mW, which is uncomfortably close to the limit. With an 18V battery D3 will probably fry.
sunday01
Joined Dec 18, 2014
Yes, I use single LED only.
I need a simple constant current source that provides ~30mA current from a 9-18V source, because this source is come from the other design that I cannot approach.
Would you please refer me another circuit that can drive this led?
Thank you so much for your help.
