Since
the regulator is floating and sees only the input-to-output
differential voltage, supplies of several hundred volts can be
regulated as long as the maximum input to output differential
is not exceeded, i.e., do not short-circuit output to ground.
Thus you only have to double the input voltage and take care of the above situation. Thus you only needs one Lm338
