how to connect ic to 8051 ???
Discussion in 'General Electronics Chat' started by gary9, Jul 25, 2009.
  1. gary9
    Jul 25, 2009
    hello guys,i am a newbie to 8051.My question is about how we should connect ic to 8051 because as you know ,direct connect 8051 to desktop will burn it off.So could you guys please tell me how to connect it ???
    Beside that could you also tell what is the name of the connector of desktop to ic,ic itself and lastly ic to 8051 ???
    (the name of the wire that connect them to together)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We need more information. What is the IC? If it is a logic IC, there may be no problem.
    This could use some explanation -
    - what is the "desktop'? It is somewhat common to make direct connections between devices like logic IC's and microprocessors by traces on a printed circuit board.
  3. gary9
    Jul 25, 2009
    the desktop is referring to personal computer or PC
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I am at a loss to see how that applies to connecting an 8051 microcontroller to an IC. What is the IC? Why is there a PC involved?
  5. rushi53
    Member
    May 8, 2009
    21
    If you have to connect 8051 to PC,
    then you can use MAX232
    and then send/receive data using serial communication
