How to connect CO sensor
Discussion in 'The Projects Forum' started by Macabra, Jun 23, 2008.
  1. Macabra
    Thread Starter Active Member
    May 31, 2008
    49
    Hi everyone,
    I've obtained this CO sensor for an experiment that I am doing at home. However, I have no clue whatsoever how it suppose to operate. Anyone with experience care to enlighten me as to how this is suppose to work? I do not understand by "working" and "counter" pin. The one and only data sheet available is attached to this thread.
    Much thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Well, the output is given as around 45 microamps/% CO, and it's an electrochemical cell. That should mean that it reacts CO with the interior chemistry to produce the rated current.
    The two terminals will have differing polarities. The working and counter designators are a head-scratcher.
    Here is a link to the Wikipedia article on such cells - http://en.wikipedia.org/wiki/Electrochemical_cell.
  3. Macabra
    May 31, 2008
    49
    Yeah, I don't have any experience with this sort of thing. I guess I could always connect the sensor with two wires connected to it and measure the output at varying CO conditions and see what voltage output I get..if any.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The signal is going to be pretty weenie. The spec sheet recommends 5 ohms to load the signal with. You might want to use an op amp as an inverting amp with a large value feedback resistor to get the signal up to more useful level.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
