how to connect 8 MIC to ADC0808, and then interface it with COMPUTER
Discussion in 'General Electronics Chat' started by alpha_tayyab, Jun 10, 2009.
  1. alpha_tayyab
    Dec 23, 2008
    11
    Hi to ALL
    i wonna connect 8 mics to ADC0808, and multiplex signals, then after multiplexing, i want to transmit the multiplexes signal to computer...
    i have completed idea in my mind, but still confuse to make circuit
    so any can anyone of u will do give me favor to complete this task!!!
    the task is
    1)1st connect 8 sound sources(MICROPHONE) to ADC0808....(i need circuit for this)
    2)2nd is MULTIPLEXING
    3) after multiplexing, how did i transmit signal to COMPUTER??? and what do i did for connection with PARALLEL port!!!
    waiting for GOOD RESPONCE
    TAYYAB
  2. alpha_tayyab
    Dec 23, 2008
    11
    here i give BLOCK DIAGRAM
    i need about the circuitry of componont(OVERVIEW)
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I suggest you get the data sheet for the converter - http://www.national.com/mpf/DC/ADC0808.html
    It has all the information you need. With only 8 bits resolution and slow switching between channels, you will get low-quality sound conversion.
  4. alpha_tayyab
    Dec 23, 2008
    11
    i like to convert with very low sound data rate....
    so would i use max147, or adc0808
    any idea/???
