Dear Microcontrollers master,
I have programmed the atmega16 to compare the Port B, port C and Port D, than out to port A as the result. the program is below :
#include <mega16.h>
// Declare your global variables here
#define tombol1 PINC
#define tombol2 PIND
#define tombol3 PINB
void main(void)
PORTA=0x00;
DDRA=0xFF;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=P State6=P State5=P State4=P State3=P State2=P State1=P State0=P
PORTB=0xFF;
DDRB=0x00;
// Port C initialization
PORTC=0xFF;
DDRC=0x00;
// Port D initialization
PORTD=0xFF;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
UCSRB=0x00;
ACSR=0x80;
SFIOR=0x00;
SPCR=0x00;
TWCR=0x00;
while (1)
if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x00))PORTA=0x00;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x01))PORTA=0x01;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x02))PORTA=0x02;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x03))PORTA=0x03;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x04))PORTA=0x04;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x05))PORTA=0x05;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x06))PORTA=0x06;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x07))PORTA=0x07;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x08))PORTA=0x08;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x09))PORTA=0x09;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0A))PORTA=0x0A;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0B))PORTA=0x0B;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0C))PORTA=0x0C;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0D))PORTA=0x0D;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0E))PORTA=0x0E;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x0F))PORTA=0x0F;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x10))PORTA=0x10;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x11))PORTA=0x11;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x12))PORTA=0x12;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x13))PORTA=0x13;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x14))PORTA=0x14;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x15))PORTA=0x15;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x16))PORTA=0x16;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x17))PORTA=0x17;
else if((tombol1==0x00)&&(tombol2==0x00)&&(tombol3==0x18))PORTA=0x18;
else if((tombol1==0x00)&&(tombol2==0x1A)&&(tombol3==0x01))PORTA=0x7F;
else if((tombol1==0x00)&&(tombol2==0x1A)&&(tombol3==0x02))PORTA=0x80;
else if((tombol1==0x00)&&(tombol2==0x1A)&&(tombol3==0x03))PORTA=0x81;
else if((tombol1==0x00)&&(tombol2==0x1A)&&(tombol3==0x04))PORTA=0x82;
else if((tombol1==0x00)&&(tombol2==0x1A)&&(tombol3==0x05))PORTA=0x83;
else PORTA=0xFA;
but it doesn't work. the program only respons to individual port, it doesn't work to compare two ports. please help me to solve the problem. thank you very much.
#include <mega16.h>
void main(void)
PORTA=0x00;
DDRA=0xFF;
PORTB=0xFF;
DDRB=0x00;
PORTC=0xFF;
DDRC=0x00;
PORTD=0xFF;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
UCSRB=0x00;
ACSR=0x80;
SFIOR=0x00;
SPCR=0x00;
TWCR=0x00;
while (1)
else PORTA=0xFA;
