How to compare reverse recovery time between diodes in different test conditions?
Discussion in 'General Electronics Chat' started by NicksonYap, Jan 13, 2013.
  1. NicksonYap
    Jan 13, 2013
    Edit:
    I think I put this thread in the wrong category...
    Wassup, newbie here :D
    This looks like a very nice forum! I've checked on some of the allaboutcircuits.com lessons and they're really informative! :D
    Okay...
    If I were to compare the trr between 1N4148, UF5408, 1N3595.
    I'm not specifically trying to compare those two diodes, but just as an example.
    I chose those because they seem to have very different test conditions.
    1N4148 (http://www.futurlec.com/Datasheet/Diodes…
    Test condition:
    when switched from IF = 10 mA to
    IR = 60 mA; RL = 100 Ω;
    measured at IR = 1 mA
    Results: 4ns
    UF5408 (http://www.futurlec.com/Datasheet/Diodes…
    Test condition:
    IF = 0.5 A,
    IR = 1.0 A,
    Irr = 0.25 A
    Results: 75ns
    1N3595 (http://www.fairchildsemi.com/ds/1N/1N359…
    Test condition:
    IF = 10 mA,
    VR = 3.5,
    RL = 1.0 kΩ
    Results: 3µs
    So, perhaps I can get a value that is relative like reverse recovery speed?
    I'm still very new to this...
    Can also explain what is IF, IR, Irr, RL, and VR?
    Thank you very much! :D
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You were right, but that is my job. I'll move it for you. :D
    Good luck.
  3. NicksonYap
    Jan 13, 2013
    Thanks! :D (and sorry)
