how to compare multiple signal with PIC18F2455
Discussion in 'Embedded Systems and Microcontrollers' started by angelita, May 29, 2010.
  1. angelita
    May 29, 2009
    25
    how to compare multiple human sound from different microphones
    to take the strongest signal (higer voltage)
    with
    PIC18F2455
    if i use 7 channels
    but the comparator is just two input
  2. mik3
    Feb 4, 2008
    4,846
    63
    You can use an external multiplexer IC or use the analog inputs of the PIC (if they are enough) and make the comparison in software.
  3. angelita
    May 29, 2009
    25
    is there any recommended software??
    what about the delay ? causes a problem right
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. angelita
    May 29, 2009
    25
    its a silly question i know ..but how to use ADC to search highest voltage
  6. mik3
    Feb 4, 2008
    4,846
    63
    By software I mean the program (code) the PIC is running. You can use any compiler/programmer you have to program the PIC.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You convert the voltages from the peak detectors on a continuous basis. The conversion with the highest value is from the channel with the loudest input.
