How to Compare 2 Numbers Using 4bit Adder
Discussion in 'Homework Help' started by athulascc, Mar 27, 2015.
  1. athulascc
    Aug 15, 2014
    88
    hi\
    I need to compare Number A and B.
    I can recognize equal state Capture.JPG .
    Also I know if A>B carry out will be 0.
    but how to recognize A<B?
  2. athulascc
    Aug 15, 2014
    88
    please help me assp
    I think if A>B then answer is positive therefore Cout=0 , since for A=B Cout=0 when Cout=0 ; A>B or A=B
    otherwise A<B
    correct?
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    Can you subtract the two numbers, and look at the carry?
  4. athulascc
    Aug 15, 2014
    88
    yes. they have given hint
    B3 B2 B1 B0 - A3 A2 A1 A0 + 2^4
    < 2^4
  5. athulascc
    Aug 15, 2014
    88
    I know substractor does not show answer well when it is out of range or negative.
    so I think only looking at carry out is not enough
  6. WBahn
    Mar 31, 2012
    18,079
    4,917
    In your first post you said that you know how to recognize A=B and you know how to recognize A>B (though I'm not convinced you do, but let's assume). Well, then if you determine that A=B is not true AND you determine that A>B is not true, what does that leave as the only possible result?
    absf likes this.
