How to commutate the BLDC motor using quadrature encoder
MaxHeadRoom
Joined Jul 18, 2013
28,686
It was originally done with 3 hall sensors, now the normal way is commutation tracks on the quadrature encoder, in some cases it can be done by the controller initially exercising the motor and using quadrature and current feedback to locate the field positions, from then on the encoder is used to commutate.
Max.
ep.hobbyiest
Joined Aug 26, 2014
201
you meant to say, we can do. We just have to compare the the count of encoder. Like
lets take 1 revoulution is of 1000 count.
1000/3=333
if i get 333 then i should commutate the A coil and if it 666 then B coil and if it 999~1000 then C coil. Is it correct?
MaxHeadRoom
Joined Jul 18, 2013
28,686
If using the encoder, then you need to initially find the relative position of the poles by exercising the motor initially to do this, then you also need to know or find the pole count.
Then the encoder position is used to commutate, I have not used this method personally but some drive manuf. have.
Search Microchip site, they have a few examples of BLDC motor control.
Max.
