how to combine 2 jfets into a dual gate fet?
Discussion in 'General Electronics Chat' started by newman123, Nov 23, 2006.
  1. newman123
    Nov 23, 2006
    I tried to buy a dual gate mosfet in Hong Kong, but failed.
    I only obtained several 2N5484 jfets,all of them having Idss small than 3mA.
    is it possible to "cascode" 2 jfets to form a single dual gate jfet?
    i want to use it to make a freq. mixer : 1 gate feed to OL , another gate feed to antenna .
    Jfet and mosfet can do the same job?
    please help!
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    yes you can, but it's better you show us how you would go about it.
    moz
  3. newman123
    Nov 23, 2006
    Actually I want to Diy a simple FM radio by using NE(AD)602/612 as a front end section.
    Unfortunately, I don't have such IC.(it's hard to buy small numbers of IC in
    hong kong.)
    now, what I have is several jfets, general pnp transistors ,lm386 and
    mc1350p.
    the most expansive instrument I got is a $10 digital multi meter.
    is it a easy task to Diy an "acceptable quality" FM radio?
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  5. n9352527
    Oct 14, 2005
    1,198
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Getting back to the production of a dual-gate FET from two single units...
    The first step would be to match a pair of FET's. Set up a rig to place each FET into that will allow you to measure the voltage between the drain and a fixed resistor to Vcc with the source grounded and a fixed voltage on the gate. Try to find two that have identical drain voltages under the test.
    Next, you will need to insure both devices run at the same temperature. TO-18 cans may be fastened together with copper wire. TO-92 cases may be epoxied together flat-to-flat. The TO-18's are easier to arrange for pcb mounting.
