How to clip transient voltages outside 0~5V range
Discussion in 'General Electronics Chat' started by tpny, May 19, 2012.
  1. tpny
    May 6, 2012
    216
    I need to make sure signal going into my adc is within 0~5V. How do I clip voltages outside this range? Thanks!
  2. #12
    Nov 30, 2010
    16,665
    7,312
    The usual way is to place 2 diodes on the signal line with one placed to allow excessive positive voltage excursions to be dumped into the positive (5v) power line and one that allows voltage excursions below zero to be dumped into the common (0 volt) line. A resistor is placed in series before the diodes to limit current through both of them. Shottky diodes have the lowest forward voltage when dumping transients.
    Then again, most devices that are sensitive to this have these diodes inside them and you have only to place a series resistor to limit the current that needs to be dumped.
  3. tpny
    May 6, 2012
    216
    Is it possible to clip it exactly at 5 volts and 0 volts?
  4. #12
    Nov 30, 2010
    16,665
    7,312
    I believe it is, but nobody has included these circuits on integrated chips that would only need a few more transistors in addition to the thousands they already contain, so I think it isn't all that important.
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    A clipper based on an op amp can do this. Use google.
  6. crutschow
    Mar 14, 2008
    13,475
    3,361
    It's possible, but it would add significant complexity, and there's no reason to do that for your requirements.
