I believe this underwater camera's contacts were damaged by ocean salt water. Up & Down buttons work but Left & Right do not. Is there any way to clean/repair them?
To be honest I didn't even notice the price. Yes it is a little expensive for your use. Someone had said something about silver paint and I remembered that stuff being available.That's over $30 out of pocket and the only theing I would need it for is this thread's topic. How about this for $9.50:
http://www.newegg.com/Product/Product.aspx?Item=9SIA0BM05Y3153
Unless local auto parts stores have rear window defrost repair kits for the same price or less.
Yes it would be dificult. However, with a little patience and some masking of areas you could do one set of fingers at a time. Use a small pointy object (tooth pick, needle, etc..) to dab the product in place. Have you tried to clean it yet to see if the copper traces are really damaged?I got the following advice elsewhere, fyi:
"Microtip pens are for restoring a straight line circuit trace. What you have with the button contacts is an interlocking finger design that is bridged by the push button to complete the circuit. It would be extremely difficult to redraw the button circuit on the board without permanently shorting the contacts. I would be looking for a replacement circuit board. "
Br1078lum
