how to check/test thyristor with the help of multimeter?
Discussion in 'General Electronics Chat' started by imtiazcl, Feb 13, 2016.
  1. imtiazcl
    Feb 13, 2016
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    Welcome to AAC!
    You can check the diode between gate and cathode with a meter, but that won't tell you if it works. Checking switching characteristics will require a test circuit.
  3. paulktreg
    Jun 2, 2008
    624
    125
  4. Dodgydave
    Jun 22, 2012
    5,155
    772
    Connect the Anode to meter red lead, Cathode to black lead, set meter to diode test, and short gate to Anode, then remove short, meter will beep if thyristor is ok, or show 0.7 to 0.9V.
