how to check pnp transister whith analog or digita
Discussion in 'General Electronics Chat' started by newone, Jan 5, 2006.
  1. newone
    Dec 23, 2005
    14
    how to check pnp transister whith analog or digital meter.
    the pnp transistor is in circuit now .
    to check it need remove from circuit
    or it can be check in transistor
    or it will check power up the circuit
  2. JoeJester
    Apr 26, 2005
    3,403
    1,230
    Did you read the link I gave you in the other thread you started?
  3. alim
    Dec 27, 2005
    113
    Hi Newone,access the link and do some practice out of circuit. A few more things to note, the tests are equally valid with an analog meter,however the polarity of the leads are reversed RED is NEGATIVE and BLACK is POSITIVE. Use on Rx10.Note the .665 or any similar value is with digital meter on diode function.Youshould take off power when testing transistors in circuit
  4. newone
    Dec 23, 2005
    14
    thanks more
    solution
