How to check phase,neutral and ground of ac wire using multimeter
Discussion in 'General Electronics Chat' started by sumitk, Sep 4, 2012.
  1. sumitk
    Aug 1, 2012
    7
    Can someone explain me the how to check for neutral,phase and ground of ac suppy using a multimeter ,if all the three wires are of same color
  2. crutschow
    Mar 14, 2008
    13,475
    3,361
    Here's an article that my help.
  3. sumitk
    Aug 1, 2012
    7
    i had checked your link but it's nt clear...!!
  4. Dodgydave
    Jun 22, 2012
    5,141
    767
    Put your meter on AC Volts setting,
    CONNECT SUPPLY
    connect meter to Phase and Neutral = 230 Volts (+/- 6% based on European standards)
    connect between Phase and Earth = 230 Volts
    connect between Neutral and Earth = 0Volts
    THE SAME WIRE THAT GIVES YOU 230 VOLTS ON TWO OF THE READINGS IS THE PHASE (LIVE)
    if you live in USA the supply will be 120V AC
    DISCONNECT SUPPLY
    set meter to Ohms
    then connect between Earth at the supply intake, and one of the wires = Zero ohms or as near to , will be the earth wire.
