how to check if the correct resistors are installed
Discussion in 'The Projects Forum' started by pancake, Oct 30, 2013.
  1. pancake
    Oct 30, 2013
    5
    i have this speedo gauge that has been previously repaired it has been removed from my bike as it has been draining my battery the clocks on this model of bike are common to fail and are VERY expensive my question is how can i safely identify the correct value of resistors (remember the resistors are not origonal and i cannot get any circuite diagrams) i will try and upload pics thanks all
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    read the color bands... or the number on them if surface mount.. resistors typically cannot be measured with an ohm meter/multimeter "in-circuit"
    be careful where this post goes.. Discussions of automotive/vehicular modifications are not allowed here.
  3. GopherT
    Nov 23, 2012
    6,303
    4,019
    I am sure the OP is referring to his bicycle. So, assuming the resistors are not burned or covered with glue, read the resistor color code and replace them. My question would be, how do you know the resistors are bad unless you see physical damage?
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    A bicycle with a speedo and a clock? ubergeeky... :D
    #12 likes this.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    What's so geeky about that?
    My bicycle has one too:
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    And a bell too...
    Where is your basket?
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    The basket is on the rear carrier.
    The bell is required by law.
    Sticking out behind the bell is the rear view mirror.
    The red button on the left handle bar is the switch for the light.
    The right handle bar is the throttle.
  8. pancake
    Oct 30, 2013
    5
    they are completly black no coulour codes on them
  9. pancake
    Oct 30, 2013
    5
    its not a mod its a repair
  10. pancake
    Oct 30, 2013
    5
    so the question remains how would i (or you) go about finding out the correct resistor value IF THERE IS NO COULOUR BANDS SHOWING and there are no circuite diagrams etc
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    Assuming that the resistor has not been damaged you can unsolder the resistor and measure the resistance with an ohmmeter.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Is this for you bicycle?
    What is the make/model of you speedometer?
    Do the resistor go between your generator and the clock?
    There just is not enough information here.
    Guys, please keep this on topic for the OP.
  13. wayneh
    Sep 9, 2010
    12,374
    3,226
    They may not even be resistors. A picture would help a lot. If they were resistors, and burnt black so badly you cannot read the bands, there may be other things wrong.
  14. GopherT
    Nov 23, 2012
    6,303
    4,019
    I hope you take advice better than you take hints.
  15. #12
    Nov 30, 2010
    16,665
    7,310
    I like your gopher, Gopher.:p
  16. GopherT
    Nov 23, 2012
    6,303
    4,019
    Thanks. I was told that my other gopher was ugly.
  17. #12
    Nov 30, 2010
    16,665
    7,310
    I agree. The least you could do was have his teeth cleaned.
    This one is just better.
