How to check if a dc motor is working
Discussion in 'General Electronics Chat' started by FREDJAJ, Nov 7, 2014.
  1. FREDJAJ
    Nov 7, 2014
    this is 12v dc motor from VW part how to check it?
    please see attached files
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Looks like it is a BLDC if the coils do not rotate, it could be an outrunner.
    Probabally run it with a RC ESC motor controller.
    Max.
    Gdrumm likes this.
  3. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    It looks brand new.
    Since VW's don't have a cooling fan, I'm curious as to what part of the car it goes to, and what kind of problem are you having?
    If it's 12v DC, I would try hooking it up to a battery (but that's me).
    ( I would check a few things with a meter first).
  4. Gdrumm
    Aug 29, 2008
    684
    36
    Oops,
    When looking up BLDC on Wiki, it says it is run off of AC?
    So don't do what I said.
  5. FREDJAJ
    Nov 7, 2014
    thanks a lot all of you, actually this motor used in transmission for (mechatronic) hydraulic pumps the TCU burned, but when check the car with scan tool i see there's no voltage in hydraulic pumps so i wanna make sure this motor is cause TCU problem., here's the hydraulic pump and motor.
  6. Gdrumm
    Aug 29, 2008
    684
    36
    This might venture into the AAC Automotive Taboo!
    Have you checked with VW, or a VW Forum?
  7. FREDJAJ
    Nov 7, 2014
    i have checked all VW's forums/blogs/groups there's nothing about this motor! only some chinese forums talks about this motor!!o_O
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    if vw is using an electric motor to dirve the hydraulic pump, thats kind of silly, since theres all that mechanical rotating energy available in there.
    FREDJAJ likes this.
  9. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    The fact it does not appear to have a commutator and has three power leads seems to indicate a BLDC type motor which looks identical to the RC type, I have a 10yr old car and that has PWM drives to fans and various motors, not sure if they are DC or BLDC though.
    RC outrunner shown.
    Max.
  10. shortbus
    Sep 30, 2009
    4,095
    1,681
    What VW's don't have a cooling fan? Even the oldest Bugs and Busses had a cooling fan, it is in the shroud above the cylinders/crankcase on the far(opposite the drive pulley) of the generator. And pretty sure all of the recent ones are water cooled. :)
  11. Gdrumm
    Aug 29, 2008
    684
    36
    Duh on me!
    I meant a radiator (with cooling fan) like a GM, Ford or Chrysler.
    shortbus likes this.
